Petit erreur ...
tecuzin
Petit erreur ...
Messagepar tecuzin » 16 mars 2019, 17:34
Hello, suite à une recheche depuis la page d'accueil du forum ("journée libre"), je tombe sur une page d'erreur avec le message suivant :
Code : Tout sélectionner
Erreur générale
SQL ERROR [ postgres ]
ERROR: for SELECT DISTINCT, ORDER BY expressions must appear in select list LINE 6: ORDER BY t.topic_last_post_time DESC ^ []
SQL
SELECT DISTINCT t.topic_id FROM phpbb_topics t, phpbb_posts p WHERE (to_tsvector ('french', p.post_subject || ' ' || p.post_text) @@ to_tsquery ('french', 'journée &libre ')) AND t.topic_id = p.topic_id AND p.forum_id NOT IN (10, 11, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 42, 43, 45, 46, 49, 51, 53, 54, 56, 57, 58, 59, 60) AND (p.forum_id NOT IN (10, 11, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 42, 43, 45, 46, 49, 51, 53, 54, 56, 59, 60, 57, 58) AND p.post_visibility = 1) ORDER BY t.topic_last_post_time DESC LIMIT 250 OFFSET 0
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
FILE: [ROOT]/phpbb/db/driver/driver.php
LINE: 855
CALL: trigger_error()
FILE: [ROOT]/phpbb/db/driver/postgres.php
LINE: 191
CALL: phpbb\db\driver\driver->sql_error()
LINE: 250
CALL: phpbb\db\driver\postgres->sql_query()
LINE: 261
CALL: phpbb\db\driver\postgres->_sql_query_limit()
FILE: [ROOT]/phpbb/db/driver/factory.php
LINE: 321
CALL: phpbb\db\driver\driver->sql_query_limit()
FILE: [ROOT]/phpbb/search/fulltext_postgres.php
LINE: 542
CALL: phpbb\db\driver\factory->sql_query_limit()
FILE: [ROOT]/search.php
LINE: 565
CALL: phpbb\search\fulltext_postgres->keyword_search()
Retourner vers « Utilisation du forum »
